20 Most Recent
A Computer By Design Open Labs MiKo TIM4 Special Edition Keyboard Workcenter PC Desktop Questions & Answers
Miko open lab does not boot. When I power up the
I had the same problem. It was a faulty mainboard so i had to built in a new one. But caution: After that all drivers will not work so you have to set up the system nes.By the way: Do you own the original Software CD?Best regards
I Installed a New Motherboard
I recently updated from XP to 7 32 bit and lost all my open labs drivers. I contacted OL and they had no problems giving me the mFusion install and touchkit drivers. After installing everything I was able to use my keyboard, touchscreen and fader controls. I no longer have the OL shell or any OL programs like Riff that came stock with the unit. Hope this helps.
Miko tim4, operating system won't start easily,
In this case I would take and restart it a couple times. Or, if you wait and not click or anything, it might work. You could also lose all your data and unplug the main power cord(leading to your main pc box) for 5 minutes. This will delete all the users on your computer. I would only do this if nothing else works or you have nothing on your computer you want to save.
WHY IS THE FREEZE PANES OPTION NOT AVAILABLE, I AM USING EXCEL 2010
Freeze Panes can normally be found under the "View" tab. If you can't find it there, it's probably not added to the view tab in your ribbon or it has been added to other tabs. To add it back to the view tab:
1. Click on the "view" tab to activate it. right click on the view tab or any part of its ribbon and choose "customize ribbon" from the popup menu. This will open the Excel Options box with Customize Ribbon activated.
2. On the right you will see "view" checked and highlighted.
3. On the left, you will see the "choose commands from" drop down menu. Click the drop down button and choose "main tabs"
4. Click on the small +box besides the "view" tab to expand it.
5. Click Windows and add.
6. Click "ok" to save your settings. You will now find the Freeze Panes in the view tab.
Short cut:
Steps 1 and 2. On lower right buttons, click on reset and choose "Reset only selected ribbon tab." Click ok and you're done :)
Format memory card
You have to be the computers Administrator to change any
values on any Hard Drive on your computer.
Click
start control panel user accounts on the users tab click the name of the
computer Administrator you must have full control.
Click
start click to open on my computer you should see your Usb drive E: or
something
right
click select properties there will be an array of options select the sharing
tab option then advanced sharing make sure you have a tick in the share this
folder box then click permissions.
Make
sure all 3 boxes are ticked full
control change and read in windows 7.
Click
start control panel user accounts click on the administrators account if you
have made one or you will have to create one in windows XP.
Click start right click on my
computer select open
Right click the icon of your Usb Drive
(It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start click on my computer
to open you should see your drive
right click then select
format
another way
Click start control panel administrative tools computer
management disk management
Right click on your usb drive select format.
How to delete songs
You cant delete anything once files are burnt to a disk.you will have to copy the music to a folder then delete the music files that you don't want then you can add more music files then burn them to another cd/dvd
Click
start click on computer to open you should see your drives C: and your other
drives cd dvd and your phone E: or F:
Right click on the the music disk to open
you should see your music
from
there you select the music files right
click on the music file/s select copy navigate back to the drive right click
select paste or hold the mouse cursor the music file/s drag them to your
computer
and paste them in usually in my
documents my music.
Invalid partition
wat is the model of the systemand the os of the system did you try the last known configuration .if not try the safe mode .if you could provide the info i might be able to help
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
