20 Most Recent Bosch Axxis+ WFR 2460 Front Load Washer Questions & Answers
14answers
Pump Blocked - Cannot open/remove cap
Sometimes it just takes brute force to open the pump cap. Try wiggling a bit from side to side; if an odd-shaped item is lodged in there, it can really be tough (but possible!) to open.
6/7/2022 7:57:16 AM • Bosch Axxis+ WFR... • Answered on Jun 07, 2022
4answers
"Door Open?"
This washer has a built in self diagnostics feature.
What you do is: With the selector knob in the off position, press and hold the "menu & select" buttons, then turn the selector knob to the "permenent press cold" until the display comes on. This puts you in the diagnostics mode, in which the last 8 errors codes will be displayed. At this point the display should read:
START-MENU T1:ERRORS
LA-Er:-------.
It gets a little hard to explain from this point on, but in my case I was able to scroll through the errors using the menu button, and I found that the were 7 errors related to the "FLOW THROUGH SENSOR".
I had already replaced the door latching mechanism without results.
Now I am going to replace the flow through sensor and see if that works, I will let you know what happens.
I have in depth information about the Axxis wfr2460 that will most likely be very helpful to owners of this machine, but I don't know how to attach it to this forum, so if you like, contact me: [email protected] and I can send you the info that I have found. It explains the whole testing procedure as well as defining the error codes, which may save a lot of frustration in solving your problem.
12/4/2021 12:28:38 PM • Bosch Axxis+ WFR... • Answered on Dec 04, 2021
My Axxis 2450 (or 2460,
Check the drain pump
12/15/2017 11:05:11 AM • Bosch Axxis+ WFR... • Answered on Dec 15, 2017
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
8/4/2017 9:18:05 PM • Bosch Axxis+ WFR... • Answered on Aug 04, 2017
My Bosch washing machine not working properly
Does the tub turn at all when you start it?
Sam
Melbourne Domestic Appliances
Text 0424395512
4/8/2017 6:36:42 PM • Bosch Axxis+ WFR... • Answered on Apr 08, 2017
Child lock stuck in "on" position.
Hello, Welcome to fixya.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
3/14/2015 12:27:26 PM • Bosch Axxis+ WFR... • Answered on Mar 14, 2015
2answers
My towels look as if they have bleach spots all over them. these are costco towels so the quality is there. it has ruined many other towels also. I do not nor have ever used bleach on this washer.
did you use resolve? i had a problem when i used it, it took the colour from one and mixed with an other.lol
1/4/2015 11:46:54 PM • Bosch Axxis+ WFR... • Answered on Jan 04, 2015
Why is my washing machine not spinning fast, only slow, so clothes are too wet.
Is the belt wore out and slipping? Check this first.
9/9/2014 2:57:05 PM • Bosch Axxis+ WFR... • Answered on Sep 09, 2014
The machine has no power at all bosh
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
7/15/2014 8:40:33 AM • Bosch Axxis+ WFR... • Answered on Jul 15, 2014
Error 16
Check your solenoid valves if the coils are healthy.
11/27/2013 3:19:42 PM • Bosch Axxis+ WFR... • Answered on Nov 27, 2013
Bosch Axxis+ WFR 2460 Front Load Washer Logo
125 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
towels look as bleach spots all over
  • Washing Machines
