20 Most Recent Texas Instruments TI-84 Plus Calculator Questions & Answers
2answers
How many ml is 5 mg?
Milliliter is a unit of volume, milligram is a unit of mass (or weight). There is no direct conversion between them. 5 mg of water occupies 5 ml. 5 mg of gold occupies about about a quarter of a ml.
11/7/2023 4:15:47 PM • Texas... • Answered on Nov 07, 2023
3answers
I want to convert 730g to ml
10/16/2023 4:25:45 PM • Texas... • Answered on Oct 16, 2023
Answer always appearing
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
4/11/2023 7:34:15 AM • Texas... • Answered on Apr 11, 2023
2answers
Why is my ti84 giving me wrong answers when I use trig functions?
Your right you should be in degree mode. However, my guess is you are somehow entering in cot wrong in your calc. Recall cot = 1/tan! In your graphing calculator enter: 35(1/tan(61) = 19.4. Hope this helped!
11/3/2022 9:45:36 PM • Texas... • Answered on Nov 03, 2022
How do you put in
For curly braces {} use 2ND ( and 2ND ). For square brackets [] use 2ND multiply and 2ND plus.
10/15/2022 6:01:22 PM • Texas... • Answered on Oct 15, 2022
2answers
What is wrong with my calculator? invNorm Error:Domain
DOMAIN ERROR: - You specified an argument to a function or instruction outside the valid range. This error is not returned during graphing. The TI-84 Plus allows for undefined values on a graph. - You attempted a logarithmic or power regression with a LX or an exponential or power regression with a LY. - You attempted to compute GPrn( or GInt( with pmt2 < pmt1.
10/2/2022 3:17:57 PM • Texas... • Answered on Oct 02, 2022
Where is the forward slash on a t1-84 plus
Use the division key.
9/25/2022 11:38:56 PM • Texas... • Answered on Sep 25, 2022
How do i reset my window settings for graphing
Hello, If by reset you mean revert to the default settings, press [Zoom][6:ZStandard] If on the other hand, you want to play with the window dimensions press [WINDOW] and change the values of Xmin, Xmax,Ymin,Ymax. Make sure that Xmin Less than Xmax, Ymin less than Ymax. If domain is positive set Xmin=0., If range is positive set Ymin =0. Hope it helps.
8/3/2022 8:33:57 PM • Texas... • Answered on Aug 03, 2022
2answers
TI-84 Plus calculator without ~ | or y keys
type 15 then click a button that looks like this^. then 365. Then hit enter. it is like a normal clcutor except with more function. Sometimes you need to use the 2nd and the alpha button to do some functions.
8/3/2022 7:02:36 AM • Texas... • Answered on Aug 03, 2022
2answers
Ti-84 BINOMIAL PDF
I encountered this same problem with the TI-84. Turns out you have to put your P (Percentage) as out of one hundred. For example. With my problem I had; Trails: 13 P: 53/100 X Value: L1 (List 1) And then it posted my probabilities to the L2 list. For some reason if you just put 53, or whatever your percentage of success in, it won't calculate.
8/3/2022 6:59:32 AM • Texas... • Answered on Aug 03, 2022
2answers
I NEED TO INPUT 20% IN MY TI-84
There is no percent function. To enter 20, simply press "." then "2".
8/3/2022 6:59:15 AM • Texas... • Answered on Aug 03, 2022
3answers
My calculator is stuck on exponential. example
remove the batteries, then re-install
3/19/2022 7:39:56 PM • Texas... • Answered on Mar 19, 2022
How do i get rid of the ERR: STAT on my graphing calculator
Here are some possible reasons for the error ERR:STAT 25420394-q2pwurzke5pnc5434ywey2dm-4-0.jpg
1/30/2022 3:23:17 PM • Texas... • Answered on Jan 30, 2022
3answers
How do I convert decimal to fractions, and
If You Want to Convert Decimal to Fraction for your maths class. These types of calculations are we can learn on 5th to 10th Standards. If you are studying in 5th to 10th class and you don't know how to convert your decimal number to fraction number. You want to learn about decimals and fractions. https://www-calculator.com/ deci to frac maths calculator-undefined-undefined-0.jpg
5/11/2020 9:20:56 AM • Texas... • Answered on May 11, 2020
3answers
My new calculator is giving incorrect answers to
Your calculator is set to radians, which is the norm for higher mathematics. To set it to degrees, press MODE to bring up the mode editor, press down-arrow twice to get the the angular mode, press right-arrow to highlight "DEGREE," and press ENTER. Press 2ND [QUIT] to exit the mode editor.
3/19/2020 8:34:57 AM • Texas... • Answered on Mar 19, 2020
2answers
My TI-84 Plus won't let me graph trigonometric functions.
Is it somehow preventing you from graphing, or are you simply not getting the graph you expect?Most likely you have the angular mode set wrong. You probably want it set to radians. Press MODE, move to the third line, highlight RADIAN, press ENTER, then 2ND [QUIT].If it's not the angular mode, please reply to this post and give an example or two.
5/18/2019 9:54:33 PM • Texas... • Answered on May 18, 2019
Texas Instruments TI-84 Plus Calculator Logo
2,178 questions posted
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Texas Instruments Office Equipment & Supplies
Most Popular Question
get domain error ti 84 plus when using
  • Office Equipment & Supplies
