20 Most Recent Mitsubishi WD-52525 52" Rear Projection HDTV Questions & Answers
2answers
Timer flashing
remove the lamp and check to see if its ok, if ok replace lamp thermal sensor
10/10/2019 8:43:03 AM • Mitsubishi... • Answered on Oct 10, 2019
5answers
Mitsubishi HD 1080 wont turn on now
did u by any chance open the assembly of the tv and touched the pcb board... the circuits on this board r very delicate and u shud be very if u r handling tis....
wen u switch on ur tv r u able to listen to any sound or wat?
if yes reply back, i wil help u
7/25/2019 11:29:37 PM • Mitsubishi... • Answered on Jul 25, 2019
How to clean air flow vent on 73 inch mitsubishi tv
I have a blinking yellow light and tv won't turn on
6/22/2018 10:36:23 AM • Mitsubishi... • Answered on Jun 22, 2018
2answers
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
1/21/2018 6:21:22 PM • Mitsubishi... • Answered on Jan 21, 2018
0answers
52 inch Hitachi rear projection HDTV. No picture. Just vertical colored lines.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
4/15/2017 11:27:08 PM • Mitsubishi... • Answered on Apr 15, 2017
Mitsubishi WD-52631 shadows and blurs in dark lit movies
Good Day;
You may have a lamp going bad,when was the last time you replaced it? Or the DMD or light engine, try lamp first. Good Luck, big IRISH.
8/7/2016 6:45:01 PM • Mitsubishi... • Answered on Aug 07, 2016
29answers
Blinking Green Light on Mitsubishi DLP 52525
Even if you replace the capacitors already mentioned in thisthread, you may still suffer from the Green LED of Death. Here is how Bronson279 helped me resolve theproblem. But note that it involvesadding a switch to your tv set and requires a bit of soldering ability and thewillingness to void your warranty. BUTyou can save big $$$$ on sending the set out for repair.Here is my solution- After replacing several bad capacitors (you can get replacement capacitorsfrom Mouser electronics on line by the way.. be sure to order the same capacitancevalues and same or higher voltage rating and be sure they are rated for 105degrees C.) I still had the dreaded G.L.O.D. Note that the first time I plugged it inafter taking it apart the G.L.O.D was not there and it powered upnormally. But when I had to unplug theset to fully re assemble it, it came back. The issue is caused by both the FMT board (formatter) andthe DM (Digital Module) board’s microprocessors tying to establishcommunications with each other. Somehow a race condition gets started with eachthinking that the other board needs to be reset and then starting the bootprocess over again. You need to interrupt this cycle with a switch. Buy a DPDT switch from radio shack (or MouserElec…) and again take apart your electrical chassis (If you have it apartreplacing bad caps you might as well add the switch or you may end up having todisassemble the whole thing again.) Onthe FMT board along the top edge near the input connector side of the chassisthere is a four wire connector labeled “FC”. It has two black wires and 1 orange and one Brown wire. Leave the black wires connected and cut the orange and brown ones about aninch from the connector. Solder four 12inch wires onto the ends (one on the source side brown, source side orange andone on the connector side brown and connector side orange) use heat shrink tubing to cover the solderconnection points. (If you can’t get tubing, then electrical tape will do, butmake sure the joints can’t short out to each other or the electrical chassis.) Now take the brown and orange wires from theconnector side and solder those to the middle two terminals of the DPDT switch(one on each side not both to both terminals) Then pick one side of the outsideterminals of the switch and solder the source side brown and orange wires tothe terminal across from the same color (brown across from brown and orangeacross from orange) See the diagram below. The idea is to connect the wires normally when the switch is closed andbreak the connection when the switch is thrown the other way. Before solderingthe wires to the switch add a piece of heat shrink tubing to wire so that youcan cover the solder point up after it is assembled. 45186c7.jpgNow re-assemble the electrical chassis and route the switch/wiresoutside the chassis (I snipped a hole along the edge of the top fan shield toget the wires out.) and put it back in the TV. You need to also get the switch to the outside of the TV somehow (Idrilled a ½ inch hole in the plastic cover to snake the switch through but youcan do it however you like)Here is how to use it- From a fresh plug in- throw the switch to the OPEN position (the wiresare not connected) plug in the TV, the green LED should stop blinking after 60secs like it is supposed to. Once it stops, flip the switch the other way sothe wires are connecting. Hit the powerbutton. The TV should turn on- your done! Yeah!From a plugged in, hmmm my power must have gone out,state. Assuming you have the GLOD, flipthe switch to the open position, hit the reset button on the front of the tv,wait for the blinking to stop, flip the switch back closed and turn the TV onnormally… Again you are done… Note that the first time you turn on the TV you may have toflip the switch the other way (if the TV won’t turn on even without a blinkingLED) This means that the switch was open and you need to have it closed to getit to work. If you tried turning on theTV with the switch open, start over by following the reset button procedureabove.Note this is much easier to do than it sounds. Also note that it helps if you have therepair manual. Its titled V26 RepairManual –full This is nice to havebecause it has a wiring interconnect diagram also which details all theconnector placements
4/27/2016 6:31:05 PM • Mitsubishi... • Answered on Apr 27, 2016
How do I adjust light tunnel on Mitsubishi 52 inch dlp tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
1/29/2016 3:21:37 AM • Mitsubishi... • Answered on Jan 29, 2016
Bulb goes out after a few minutes
The ballast for the bulb is the culprit. That is the circuit board directly wired to the bulb. You can get a replacement on line at: TV Parts Universal TV Stands DLP Chips ShopJimmy It's not difficult to change it yourself .
8/8/2015 10:24:29 PM • Mitsubishi... • Answered on Aug 08, 2015
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,606 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
bulb goes out after few minutes
  • Televison & Video
