20 Most Recent Oritron DAV3101 PROGRESSIVE SCAN DVD Questions & Answers
3answers
2answers
Oritron DAV3101 User Manual
KOSS put out the exact same unit. Theirs is available athttp://www.hifi-manuals.com/Download/KOSS/KS-3101-A-2-owners-manualYou need to register to download but it's free.
8/3/2016 10:04:40 PM • Oritron DAV3101... • Answered on Aug 03, 2016
0answers
Ford Fairlane 1992 start up problem
hello maurice,sounds like you have a few possible problems on hand there.1st off,if cars fail to start,esp on a wet or damp days,nearly always the air density has changed to such a state,that atomisation is not taking place [fuel is not vaporizing in to the combustion chambers]and creates a 'heavy' state of which the fuel cannot burn properly [ignite] you need to be certain that your car is in fairly good mechanical condition,and all the relevant criteria[ignition system,plugs,coils,sensors,air filter/fuel filters are in a serviceable condition,merely guessing that your fuel pump is useless,is not the correct way to go with your particular problems here,as you can get the line pressure checked without dis-assembly,establishing the overhaul condition of the working pressure of the pump,as 'suspicion's' of this that and the other,will certainly wipe out your bank account,and may not solve your particular problem.cheers,and hope that this has helped.
6/2/2014 5:57:14 AM • Oritron DAV3101... • Answered on Jun 02, 2014
Microphone inputs
u need to turn on the mic in the menu
12/29/2013 2:48:44 AM • Oritron DAV3101... • Answered on Dec 29, 2013
0answers
2answers
Region Code!!!!!!!!
HELLO
I am not sure what model DVD player you have, but it MAY help you to look at the DVD Hacks section on this website: www.videohelp.com
I'm not saying for certain your hack is there, but it might be!
ALL THE BEST! (:-)
6/11/2013 3:45:30 AM • Oritron DAV3101... • Answered on Jun 11, 2013
Need manual how to hookup oritron dav 3102
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
12/30/2011 3:45:15 PM • Oritron DAV3101... • Answered on Dec 30, 2011
110v accidentally plug in to
Without that info it's a **** shoot. The best you can do is Google the make and model number with the word schematic at the end. With any luck, you will find several sites that you can go to to look up or purchase the circuit diagrams and parts with their values.
9/4/2011 5:25:18 AM • Oritron DAV3101... • Answered on Sep 04, 2011
Power supply board damaged by lightning would like
Damage due to lightning would not be limited to power board only, in my opinion, other circuit board would have also been damaged so new home theater system would be good choice rather repairing this one.
Thanks.
5/27/2011 12:57:31 PM • Oritron DAV3101... • Answered on May 27, 2011
2answers
Oritron DAV3102 No sound to speakers
I have the exact same problem. It stopped working a couple of days ago. Let me know if you find a solution.
Thanks, Nicco
[email protected]
5/25/2010 6:54:37 PM • Oritron DAV3101... • Answered on May 25, 2010
2answers
My oritron dav 3102 when you tern on the dvd,the
sorry i dot not solve the problem,but i need to know if you have spanish techs to chat???
5/25/2010 6:39:40 PM • Oritron DAV3101... • Answered on May 25, 2010
Lost manual need help setting dvd home theater to
THIER IS A VIDIEO OUT NEXT TO THE COMPONTENT GENERALY THIER MAY NOT BE AN AUDIO OUT PUT SINCE THE SOUD COMES FROM THE BUILT IN AMP HOOKING UP TP THIS WILL LET ALL DEVICES BE DISPLAYED ON THE TV ONCE THE PROPER INPUT CHANNEL HAS BEEN SELECTED THEN YOU WILL ONLY HAVE TO SELECT THE AV ON THE SURROUND SOUND SYTM TO SWITHCH IVIDOE AND SOUND FOR EACH DEVICE PLUGGED INTO THE SYTEM
12/20/2009 9:50:59 PM • Oritron DAV3101... • Answered on Dec 20, 2009
What type of fuse does the Oritron DAV3101 use?
THE FUSE TYPE IS POSTED RIGHT NEXT TO THE FUSE ON THE CICUIT BOARD
12/20/2009 9:45:46 PM • Oritron DAV3101... • Answered on Dec 20, 2009
2answers
DAV3102 not enough volume
I have a DAV 3101 and the sound level is much better if the optical input is used. If you use other then supplied speakers you can blow the unit up. It uses 50uF electrolytic capacitors inside the front speakers (3) TO SAVE SPACE IN THE MAIN BOX. However, my unit will shut itself off. Standby light flashes and won't turn on until line cord power is reset over nite. Too bad Oritron doesn't support their products. Their web site is poor. I couldn't find an authorized repair service. Buyer beware! Tom H
12/20/2009 9:44:17 PM • Oritron DAV3101... • Answered on Dec 20, 2009
Televison & Video Logo
38 questions posted
Popular Products
Top Oritron Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Oritron Televison & Video
Most Popular Question
ford fairlane 1992 start up problem
  • Televison & Video
