20 Most Recent
Copystar CS-1650 All-In-One Laser Printer Questions & Answers
A3-200 error code
that code points to your exposure lamp not lighting. that lamp is the one under the glass that scans your originals. you will need a tech that has parts access to replace.
razors
I have a copy Start CS 1650 with the error code
there is no C400 code, but there is a C4000 and its a pretty common code on these boxes. it's pointing to your laser unit. definetly not easy to get to. you will have to have laser unit replaced or sometimes i have had luck pulling out laser, pulling polygon mirror out and lubricating the shaft. that only works about 50-60% of time however and if you are paying a tech to do this work, you may just want to replace it as it is fairly time consuming to get laser out.
hth,
razors
Kyocera 1620 error code c-4 000
that code, unfortunately, means your laser unit has went south. you definetly have to call a tech on this as it is quite a job to even get to the laser.
hth
razors
Copystar
Press the Printer key.
Use the up / down keys to find "Menu", then select with the Enter Key.
Use the up / down keys to find "Others", then select with the Enter Key.
Use the up / down keys to find "Printer Reset", then select with the Enter Key.
Use the up / down keys to find "OK", then select with the Enter Key.
