20 Most Recent
JVC XL-MC334 200-Disc CD Changer Questions & Answers
Put in the wrong email
I looked at a picture of the rear of your player and it takes a standard power cord commonly used on boomboxes and similar products.
Radio Shack carries a suitable replacement.Their website says it's available in most stores. You might also try thrift/resale shops in your area where cords are often for sale. (I think I have a couple of these cords. If you want to email a postal address to
[email protected] I'll be happy to send one if I do.)
I need to know how
You can download the manual from the manufacturer's web site at
http://resources.jvc.com/Resources/00/00/99/LVT0022-001B.pdf
Had some power surges and now the unit (XL-MC344)
There is a fuse in this unit but it will require a soldering iron to change it. Fuses are rarely the problem. This unit uses a switch mode power supply along with a small transformer for the standby voltage. It is possible that the internal fuse for the standby transformer has opened. The fix for this would be to replace the transformer. This is a common problem with lightning strikes and power surges. WIthout seeing the actual unit, I can't say that this is the problem for sure, but it is likely. Please note that JVC service manuals are not usually available outside of Authorized service centers.
If you can update this with your location, perhaps I can direct you to a local service center.
Dan
XL-MC334 200 disc changer won't play or open
If CDs are inside the cd changer and the changer does not open try the following:
Unplug power cord.
Plug back power cord, press start, and press repeatedly the eject/open button while unit is starting, before it starts reading the CD.
This will open the unit in case it is stuck because of a bad or dirty CD inside.
If that does not work you will need to take apart the unit to remove the CDs.
Disks do not feed properly
open the player wit door ejected then clean the dust particles inside it wit dry cloth especially near the rubber belt which is connected to the dc motor... clean the lens also then check whether any screws are loose if so tight it then try playing....
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue:
Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection.
Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue.
Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues.
Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on.
If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM •
JVC Audio...
Answered
on Feb 02, 2024
1997 JVC RC-X270 does not read CDs
A bit of basic knowledge is required first;
Insert CD, the first thing the processor expects is to scheive Focus.
When Focus is acheived, the Spindle Motor will turn.
Either the Laser cannot Focus or there is an issues with the Spindle Motor.
Which is it ... if you know, then you will know which part or board has the issue.
1/29/2024 6:36:28 PM •
JVC Audio...
Answered
on Jan 29, 2024
