20 Most Recent
Cyberhome CH-LDV1010A Portable DVD Player Questions & Answers
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
1/14/2020 8:31:03 AM •
Cyberhome...
Answered
on Jan 14, 2020
"invalid key" error
your set needs a tech take it to be repair you cannot do it yourself if you do not have a knowledge of electronics repair.good luck
2/15/2017 1:09:18 PM •
Cyberhome...
Answered
on Feb 15, 2017
Will not play. just keeps saying read
First you need to try other disc on it to confirm if it is not the disc you were trying to play, if it does the same, then the lens of the player is faulty.
Therefore the reason your portable dvd player keeps reading disc without playing it is either because the lens of the player is weak or dirty.
Try to clean it with a dvd lens cleaner and test it with a disc after cleaning it. if it does the same, then the problem is that the lens is weak and needs replacement.
To replace the lens, get the appropriate screwdriver, unscrew the player from the bottom, you will see the battery and panel of the player, carefully unscrew it and remove the panel, you will see the compartment where the lens of the player is seated, carefully detach it from the player and replace it with a new one. Then you reverse the process to reassemble the player back together.
Take care
6/29/2010 1:58:24 AM •
Cyberhome...
Answered
on Jun 29, 2010
CyberHome Dvd Player, Model: CH-LDV 1010A
I have two of these batteriers if you still need them. I'd rather not throw them away if they could be put to use. You pay shipping they are yours for free.
Frank
8/20/2009 1:26:07 AM •
Cyberhome...
Answered
on Aug 20, 2009
Dvd player 1010a portable
Sorry nto tell ya that something must have happened to the lcd screen or display. Has it been dropped ?? If you hold it up to a light do you see an image but no brightness as could also be a backlight problem . My advice would be to see if theres any type of warrantee on the unit cause from experience this repair PROBably is'ent gonna be cheap and I say this cause most repair centers wont even look at something like this for under 30 to 50 bucks. Good Luck
12/8/2008 1:05:09 AM •
Cyberhome...
Answered
on Dec 08, 2008
