20 Most Recent Philips DVP642 DVD Player Questions & Answers
2answers
Won`t play disney movies
Apparently this is a known issue. Some dvp642 players have compatibility issues with some of the Disney DVD's. A firmware update might help. There is a discussion of this at: http://www.videohelp.com/forum/archive/t317193.html
2/15/2022 2:05:55 AM • Philips DVP642... • Answered on Feb 15, 2022
Philips dvp2280 region dvd region code setup
Please follow the below procedure to set the regional settings of your choice on your Philips DVD player: Step 1: Turn on your DVD player (without disk) Step 2: Press "Setup" from the remote Step 3: Go to the "Preferences" Step 4: Enter "138931" and the current zone will displayed Step 5: Use the Up and Down arrows to change area (0 = multi-zone) Step 6: Press "¨Play" on the remote. Or you can use Leawo Blu-ray Copy to make the Blu-ray/DVD disc to region-free, so that you can play it with any Blu-ray player or computer. It is one of the best Blu-ray copy software to copy and back up Blu-ray/DVD/ISO files to hard drive or blank Blu-ray/DVD disc. This Blu-ray Copy software could help preserve your Blu-ray/DVD discs and keep them away from damages. It could copy and back up Blu-ray/DVD disc to computer in folder and/or as an ISO file, or back up Blu-ray/DVD disc to blank discs in 1:1 rate. Source: https://ccm.net/faq/3767-how-remove-regional-lock-on-a-philips-dvd-player
7/26/2021 8:40:15 AM • Philips DVP642... • Answered on Jul 26, 2021
2answers
Philips DVP Playing problem
try to clean or change the laser
2/16/2020 7:48:26 AM • Philips DVP642... • Answered on Feb 16, 2020
2answers
In my Philips DVD players,
The DVD you're using is probably from elsewhere than the region you live in. It is almost certainly possible to temporarily change the region by using a trick which will not damage your machine in any way. Google "Philips DVP642 region hack" and there will be an answer.
1/14/2020 8:54:28 AM • Philips DVP642... • Answered on Jan 14, 2020
2answers
Wrong region error
Try searching the net for 'region code hack' for your model number. You can try on Fixya too, this time just put the above. If anyone knows it you should get a reply.
11/12/2018 9:55:35 AM • Philips DVP642... • Answered on Nov 12, 2018
Phillips DVP642 DVD Read Error
12/9/2017 12:37:03 PM • Philips DVP642... • Answered on Dec 09, 2017
My Philips dvd player model DVP642/37 is not
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty.
4/21/2017 3:18:55 PM • Philips DVP642... • Answered on Apr 21, 2017
Player won't open. how do we reset?
my dvd player is stand on the red light when i insert the dvd the dvd will hand after few seconds what is the problem please solved my problem
1/10/2016 9:34:18 AM • Philips DVP642... • Answered on Jan 10, 2016
4answers
Need to replace capacitor on dvd player
Hi, you should use a capacitor with same capacitance of 1000uF, but you don't have to stick to the original voltage spec. 1000uF 10V means it can withstand 10V load. 1000uF 50V means it can hold 50V for the same capacitance. Today I fixed my friend's and for that I used 1000uF 35V from RadioShack. It perfectly works - and it's better. But you shouldn't use 1000uF 5V - by now you already know that :)
3/9/2015 6:59:14 PM • Philips DVP642... • Answered on Mar 09, 2015
2answers
Philips dvd player 616k
have you tried to record in sp then playback on same machine if this works then your drum for recording in lp or if yours has ep mode may need replacing as pre recordings are ok you need to get it serviced. hope this goes well
1/14/2014 3:34:16 PM • Philips DVP642... • Answered on Jan 14, 2014
When i run my dvd on TV . it is colourles. why it
Check that you have the right input on DVD
11/7/2013 9:45:03 PM • Philips DVP642... • Answered on Nov 07, 2013
manual
manual
manual
2answers
My intergrated dvd is playing up
Sounds like the laser head to me.
6/21/2013 2:58:53 PM • Philips DVP642... • Answered on Jun 21, 2013
0answers
Philips DVP642 DVD Player Logo
201 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
black white picture
  • Televison & Video
