20 Most Recent
IBM ThinkPad T23 Notebook Questions & Answers
Ibm t23 laptop dvd rom not reading some dvds
Sounds like you need a DVD decoding software, ie... winvid, interdvd, and powerdvd. Windows media player will play some DVD's, but many DVD's, especially newer ones, need an additional decoder in order to work. You will be able to find the software at filehippo.com, download.com, or IBM's support site. Keep in mind that burning software, ie... nero, roxio, and dvd shrink, have decoders in order to burn the DVD, so they will work as a decoder in conjunction with your media player.
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
- IBM ThinkPad T23 maximum RAM capacity: 1GB
- Your IBM has Two (2) memory slots or sockets
- Module upgrade PIN count is: 144-PIN
- The memory speed is: SDRAM 133MHz, PC133
- The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
- Non ECC
If you are meeting these requirements, you may have a defective module.Also, according to
Lenovo's page on the machine:
MemoryThe
system has 128MB or 256MB of memory standard and can be configured for
up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO
DIMMs each can be added in the two available slots for memory expansion.
The standard 128MB of memory is expandable up to 640MB and the 256MB of
memory is expandable up to 768 MB of addressable memory with 64, 128,
256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is
standard in one of the internal slots for memory. For customers that
need the maximum 1GB to which memory can be expanded, it is necessary to
replace the 128MB or 256MB card with a 512MB card plus add another
512MB card in the extra slot. Only 133MHz DIMM memory can be used in
this system. The use of 100MHz DIMM memory is not supported in the T23
systems.This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting. I hope this helps & good luck!
Set clock time
Go to control panel, click on clock, language and region if using windows 7, date and time for XP
Vga for ibmthinkpad 26474pg
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive.Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows device drivers foryour model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=trueYou can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
Missing pci managment bus driver
Download the Chipset drivers. Get onlineand got to www.google.com In the google search box type: "IBMSupport" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Chipset drivers.
How to replace backlight on a ibm thinkpad t23
The backlight fault could be caused by a faulty inverter that supplies high voltage to the CCFL lamp OR the CCFL lamp could be faulty.The inverter is located at the bottom of the LCD screen between the laptop's hinges behind the plastic bezel surrounding the screen,The CCFL lamp is located on the bottom edge of the LCD screen behind a reflector that runs along the bottom edge of the LCD screen. The reflector is taped to the bottom edge of the screen.To get access to the inverter, remove the plastic bezel.To get access to the CCFL lamp, remove the screws that secures the hinges to the base, disconnect the video cable and inverter power leads from the motherboard.Remove the plastic bezel, it may have double sided tape securing it to the LCD screen, BE CAREFUL you do not damage the glass on the LCD screen.Remove the screws that fix the LCD to the lid.Now you can get access to the reflector and CCFL lamp. Carefuly remove the tape as you will need it to fix the reflector back onto the LCD.
My ibm thinkpad t23 will not go pass blue windowxp screen need help
There are many possible reasons for a blue screen at windows xp.the most likely ones are:damaged windows instalation - in which case you will need to reinstall windows.damaged physical drive - in which case you would need to get a new hard drivethe OS cannot access memory - could be RAM memory or HDD.I'm guessing you would just need to re-install the windows. You are most likely to lose all data.
How do I add a Bluetooth to IBM T-23?
<p>The T-23 notebook is an IBM system is a lightweight, so it
is ideal for transport. In terms of connectivity, the system has multiple USB
ports and an infrared transceiver. Bluetooth devices has been featured in more
than is infrared, so Bluetooth would be a valuable addition to the system. <br />
<p><br />
<p>1. Put your laptop and wait for it to fully boot. <br />
<p><br />
<p>2. Plug the dongle into a free USB port on your laptop. The
USB ports are located on the computer. <br />
<p><br />
<span>3.
Wait until your laptop to the lack of drivers to load, a Bluetooth icon in the
system</span>
Forgot my password to power on my ibm t23 what can
If a BIOS or HD lock password you are out of luck.
BIOS password means replacement of the system board. HD password requires replacement of the HD and reinstallation of all software on new drive.
This is a security feature so no one can steal laptops and try to use or sell it.
