20 Most Recent
Vizio 55" M550NV Razor LED LCD HDTV, 1080p Questions & Answers
No pic or sound
Is it getting power? Could be a loose AC input as a simple check.
T-con board
The T'Con board will have a number printed on it. It should be noted, before ordering a new one. To buy it on line, check this link.
www.alibaba.com. If you wish to get more
details, check the site linked here. Pull up older posts.
Vizio m550nv backlight won't work
This TV comes with a remote that connects to the TV via Bluetooth. It
remembers which equipment is connected to the various inputs, and
automatically changes the controls to match the input equipment - really
nice! I found that it will control all my equipment, and since it
works via bluetooth, you don't have to have direct line-of-sight to the
TV. Wish that the bluetooth part worked for my satellite equipement too!
Programmable remotes will operate this TV, but depending on how old
they are, they may not be able to hit all the features of the tv - our
older directv remotes will operate the basic features, but only the
newer models will change the input source - so you may want to use the
remote that came with the TV. We have smaller kids, and wanted to limit
their use of the tv remote, because it has a slide-out keyboard similar
to those on some cell phones to make posting to facebook (one of the
apps that comes on the tv) easy. Since our youngest is 5, we thought it
might be best to keep that remote out of harm's way.More Detail :
http://tv.babybi.com/detail.php?id_detail=VIZIO-M550NV-55-inch-Full-HD-1080p-120Hz-LED-LCD-HDTV-id126a
Vizio all in one computer VIZIO CA-27 voltage and part number for subwoofer/power supply replacement
The power supply/subwoofer for the VIZIO CA-27 series all-in-one PCs is identified by the part number 715G6960-P02-001-002S or ADTVE1825AC71. The power supply connects to the motherboard via a proprietary dual jack Audio/Power cable. I couldn't find specific voltage details for the subwoofer/power supply in the available resources. For precise information, I recommend checking the user manual or contacting VIZIO customer support directly.
Why is my Vizio TV stuck on mute.
The one logo is coming from the set top box that is supplying the signal, cable box, satellite box, Android box etc. Look for Mute on that remote, or cut the power to all your devices by removing the wall plugs. Wait 15 minutes and plug back in.
