20 Most Recent Vizio L32 32 in. LCD HDTV Questions & Answers
3answers
HDMI not working
That's the HDMI cable
2/28/2024 11:12:22 PM • Vizio L32 32 in.... • Answered on Feb 28, 2024
11answers
Closed caption wont turn off
I have a Vizio VX37L that i purchased on 12/26/08 and I had the same problem by 1/4/09. My five year old son loves to futz around with buttons and switches and he somehow enabled closed captions from the front of my Motorola digital cable box (I had it hooked up to the Vizio via HDMI 1.)
What you need to do is turn off your cable box and leave the Vizio on. Hit the "Menu" button on the front of the cable box and that should bring up a setup screen on your TV. Using the down cursor button on the front of the cable box, go down to the "Close Caption" section on the setup screen. It probably says "Enabled." Click on the right cursor button to disable CC and you should be good to go.
10/21/2023 4:55:14 PM • Vizio L32 32 in.... • Answered on Oct 21, 2023
Green Square appears on screen
Had same issue with my LG so I trouble shot the issue by noticing the green square would disappear if I switched to dvd(HDMI-2 ) Or HDMI-3. Which lead me to believe it was being generated by my Xfinity box (HDMI-1. So I first rebooted box. With no success I then unplugged box all together. Tah Dahhh! Problem fixed. Hope this helps.
12/22/2021 5:58:13 PM • Vizio L32 32 in.... • Answered on Dec 22, 2021
2answers
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
7/26/2021 11:29:02 PM • Vizio L32 32 in.... • Answered on Jul 26, 2021
3answers
Hisense LCD32V77
it must be a power supply malfunction; if you`re not a tehnician , please contact the nearest repair shop.
12/2/2019 6:03:53 PM • Vizio L32 32 in.... • Answered on Dec 02, 2019
LCD TV blows fuses
Since the main fuse is being effected, it suggests that there is a major problem in the power supply section. I would be looking for a shorted rectifier diode. If you have any experience with electronics, you may be able to locate this problem. If hte set is still in warranty, return it for warranty service. If not, try loking for burned components etc.
Dan
9/16/2019 1:33:41 PM • Vizio L32 32 in.... • Answered on Sep 16, 2019
2answers
Received a lock input message
Is the input locked or are you trying to unlock it?
8/18/2019 3:50:26 PM • Vizio L32 32 in.... • Answered on Aug 18, 2019
9answers
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
7/25/2019 2:31:12 PM • Vizio L32 32 in.... • Answered on Jul 25, 2019
2answers
"not support" message on Vizio tv when trying to use HDMI with Xbox.
Can we talk about how it says “not support” and not “not supported” that bothers me more then thinking about the TV being broke.
I just turn my cable box off then back on and it resolves the issue for a while.
4/24/2019 5:35:36 AM • Vizio L32 32 in.... • Answered on Apr 24, 2019
10answers
The picture on my tv is too big
The other poster was right, there is a zoom button on my CABLE REMOTE and once I pressed that my problem was solved. It's funny none of the techs knew that, at either Vizio or Comcast.
Hope this helps.
2/17/2019 5:35:15 PM • Vizio L32 32 in.... • Answered on Feb 17, 2019
3answers
What is the white paste looikng stuff on the capacitors
Some say its' for "heat dissipation". I'm not sure about that. I would think it would insulate the heat (like a blanket), than to dissipate it. To dissipate heat properly, it needs a heat sink made from aluminum or a fan.If your capacitor is overheating, then something else is wrong. They should not get hot. They do go bad, but they should not get hot. If they get hot, then you have a bigger problem. Capacitors should only get warm - if that. Usually they are cold, during operation, unless they are near a heat source.
2/11/2019 9:39:52 PM • Vizio L32 32 in.... • Answered on Feb 11, 2019
Can I use your remote universal Llz414
Wholesale VIZIO DPS-200PP-190 2950318703 POWER SUPPLY UNIT ,cheap price ,and orginal board ,good quality https://www.abctay.com/vizio-dps200pp190-2950318703-power-supply-unit-p-1644.html
9/10/2018 8:11:46 AM • Vizio L32 32 in.... • Answered on Sep 10, 2018
VIZO 42 LCDTV Will power on, but no PICTURE and wont power off
The EEPROM on the main board is damaged, you may change the main board, or change the EEPRON on the main board (You may find one on EBay cost $15.00 to $25.00)
1/16/2018 12:11:46 AM • Vizio L32 32 in.... • Answered on Jan 16, 2018
My vizio vp322hdtv10A just quit working
2008?. Well anyway, Do you have a power light, if flashing... panel needs replacing...if no light...power board needs replacing
1/14/2018 11:02:31 PM • Vizio L32 32 in.... • Answered on Jan 14, 2018
GE 57 inche HDTV
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ //
1/11/2018 2:53:31 PM • Vizio L32 32 in.... • Answered on Jan 11, 2018
Vizio L32 32 in. LCD HDTV Logo
2,362 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
white paste looikng stuff capacitors
  • Televison & Video
