20 Most Recent Vizio GV42L 42 in. LCD Television Questions & Answers
25answers
42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
2/22/2019 11:01:02 PM • Vizio GV42L 42... • Answered on Feb 22, 2019
I have a Vizio VW42LFHDTV10A -- The first time I
Please check for bad electrolytic capacitors on both main board & power supply, if there is any "pup-up" one, replace it (them).
8/16/2017 8:40:26 PM • Vizio GV42L 42... • Answered on Aug 16, 2017
3answers
I turn on the tv and i get a blue screen for 5 seconds and the tv shuts off. Any ideas?
This is normal on vizios, ours does it too. You have it switched onto RGB input. You need to change input after it comes on. Switch on and keep pressing change input button till it changes and then it will be fine. Alternatively plug in a computer on Rgb and then turn on, you will be able to change input normally.
5/23/2017 4:14:13 AM • Vizio GV42L 42... • Answered on May 23, 2017
Vizio LCD TV SV470XVT1A displays horizontal or vertical lines
Remove the TV cabinet to expose the circuit boards and plug and unplug the connectors the main circuit board, that many times will fix the issue.
4/4/2017 1:18:11 AM • Vizio GV42L 42... • Answered on Apr 04, 2017
2answers
Vizio E422VA 42 in LCD television power light blinks
Hi I have Vizio e422va it's not turn on only front power light is on white when I plug power coward no led no screen is black please help
1/2/2017 3:57:05 AM • Vizio GV42L 42... • Answered on Jan 02, 2017
Vizio gv42l hard reset
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
9/2/2016 2:14:16 AM • Vizio GV42L 42... • Answered on Sep 02, 2016
No pic no sound. remote doesn't work and have to
maybe you have to bring your tv to repair center
7/18/2016 4:46:33 PM • Vizio GV42L 42... • Answered on Jul 18, 2016
8answers
CRACKED LCD PANEL Vizio GV42L 42 in. LCD
Try to find new screen on amazon here Amazon com vizio 42 screen replacement. Hope this was helpful. cheers
3/20/2016 1:19:47 PM • Vizio GV42L 42... • Answered on Mar 20, 2016
GV42L HDTV picture ok but no sound.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2/26/2016 8:06:07 AM • Vizio GV42L 42... • Answered on Feb 26, 2016
I have a vizio gv42l fhdtv10a I have no picture or sound.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
2/14/2016 2:03:56 PM • Vizio GV42L 42... • Answered on Feb 14, 2016
2answers
The audio on my vizio tv isn't working
Replace the main board. That board controls all the symptoms you're having. You can get the Vizo Main Board 3642-0182-0150 thats the board for your model from www.tvcircuitboards.com it has a 6 month warranty
1/25/2016 5:32:56 AM • Vizio GV42L 42... • Answered on Jan 25, 2016
How do i fix ?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
10/31/2015 5:38:12 AM • Vizio GV42L 42... • Answered on Oct 31, 2015
2answers
I need help with disassembly of Vizio GV42L LCD TV
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
8/30/2015 7:39:54 PM • Vizio GV42L 42... • Answered on Aug 30, 2015
2answers
Hello there. My son hit my 47 in flat screen LCD
The screen is the most expensive part of the whole TV, save money for new set.
8/27/2015 2:57:01 PM • Vizio GV42L 42... • Answered on Aug 27, 2015
Heard a pop then no power how to fix
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
8/22/2015 3:09:45 PM • Vizio GV42L 42... • Answered on Aug 22, 2015
625 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
gv42l hdtv picture ok but no sound
  • Televison & Video
