20 Most Recent Targus PAUH217U 4-Port USB Hub Questions & Answers
2answers
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
3/30/2016 8:43:03 PM • Targus PAUH217U... • Answered on Mar 30, 2016
8answers
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
5/18/2014 11:44:35 PM • Targus PAUH217U... • Answered on May 18, 2014
2answers
Cable for Targus 4 hub usb2 model PA055u
Use any USB cord available at electronics stores that has a male on one end and a female on the other, obviously of the correct length.
1/23/2013 1:01:02 AM • Targus PAUH217U... • Answered on Jan 23, 2013
Hi there I have a Targus
Hi you may need to install the driver for that "Hub" also make sure that it is compatible with your system? make sure that the unit is USB compatible, usually it must be a USB 1 or USB2 version.. but in any event when it is first plugged in there should be a **** **** noise that indicates that it has been inserted, Windows should then detect it and install the necessary hub drivers, if it doesn't do so, then you may have to upgrade your USB layer? Do you have all service packs installed?, or even perhaps remove and reinstall the USB layer, to do this go to control panel, and then system, then device manager, find the USB part and right click on it and REMOVE everything and reboot, then windows will reinstall the layer again, and now you should be able to insert the Hub and it should be detected, have the driver install and work.
Also have a look at these troubleshooting links below they will assist you too..
http://support.microsoft.com/kb/310575
http://webcache.googleusercontent.com/search?q=cache:bUVhSp2zU3QJ:www.earthtym.net/USB-solutions.htm+troubleshooting+usb+ports&cd=3&hl=en&ct=clnk&gl=nz
9/19/2011 4:11:10 AM • Targus PAUH217U... • Answered on Sep 19, 2011
My Targus keeps disconnecting what is connected to
This USB hub is not powered by an AC adapter. Therefore, some devices that need more power will not work well on it. You don't mention what it is you are pluggin into it, but I suspect this may be your problem. Devices like webcams pull way too much to be on a hub without AC.
Did I solve your problem? If so, please rate this. ty.
2/26/2010 2:32:47 PM • Targus PAUH217U... • Answered on Feb 26, 2010
How to open a Targus Chill Mat Pad AWE61US N2953
Without specific details about the type or model of the mat you're referring to, it's challenging to provide precise disassembly instructions. However, I can offer some general tips that might help you access the inside of the mat for cleaning without causing damage:
  1. Consult the Manual: If the mat came with a user manual or assembly instructions, refer to these documents first. They often contain disassembly guidelines or tips for cleaning.
  2. Look for Access Panels or Fasteners: Many mats or fitness equipment have access panels secured by screws, clips, or fasteners. Carefully inspect the mat's exterior for any visible fasteners or panels that might provide access to the inside components.
  3. Check for Removable Parts: Some mats might have removable parts like covers or casings designed for cleaning purposes. Gently try to detach these removable components, following any instructions in the manual or indications on the mat.
  4. Contact Manufacturer Support: If you're unable to find a way to disassemble the mat safely or if you're concerned about causing damage, consider reaching out to the manufacturer's customer support. They can provide specific guidance on disassembly and cleaning for your particular mat model.
  5. Online Resources: Look for online resources such as instructional videos or forums where individuals might have shared tips or experiences on disassembling and cleaning similar mats.
Always approach disassembly cautiously to avoid causing damage or voiding any warranties. If you're unsure or uncomfortable about disassembling the mat yourself, seeking professional assistance from a technician or contacting the manufacturer for guidance might be the best course of action.
12/17/2023 11:49:21 AM • Targus Computers... • Answered on Dec 17, 2023
.Yo I have a Targus ipad keyboard case that is cracked open in the back
1. remove all screws 2. buy white glue epoxy 3. mend all broken sections 4. fix them back and screw them after they dry
8/13/2022 3:29:43 PM • Targus Computers... • Answered on Aug 13, 2022
Looking for a targus apa01 wire diagram to connect to computer
Contact Targus directly to request the wiring diagram.
10/19/2021 12:43:00 AM • Targus Computers... • Answered on Oct 19, 2021
I have a targus bluetooth speaker mid#2550913 for got the pin
Try 0000 or 1234
6/26/2020 10:14:08 PM • Targus Computers... • Answered on Jun 26, 2020
Targus BEU0564C driver
Try Snappy Driver Installer - Install and Update Drivers is Free and no Ads or Malware https://sdi-tool.org/
2/27/2019 1:15:11 PM • Targus Computers... • Answered on Feb 27, 2019
Where did i get targus presentaion USB Stick
I found one on Amazon. Wireless Presenter, ON THE WAY RF 2.4GHz Wireless Presenter Remote Presentation USB Control PowerPoint PPT Clicker. see the link below. https://www.amazon.com/Wireless-Presenter-WAY-Presentation-PowerPoint/dp/B06Y5ZGPX1/ref=sr_1_1_sspa?ie=UTF8&qid=1542643943&sr=8-1-spons&keywords=targus+presentation&psc=1 presenter-bzex1t3xi1odt41tgkzajjgr-5-0.png
11/19/2018 4:16:20 PM • Targus Computers... • Answered on Nov 19, 2018
4answers
How to install epson stylus
I have the same printer; first need install the drivers, according woth your OS (Operative System), this drivers can find and donwload from this link: printers_and_all_in_ones/Epson_Stylus_T13
Just select your OS and donwload, install the driver and follow the guide step by step.
Good luck.
11/13/2018 6:02:03 PM • Targus Computers... • Answered on Nov 13, 2018
Print from targus tablet
google targus with make model and serial and go to support/download and get user manual.pdf
9/30/2018 8:36:14 AM • Targus Computers... • Answered on Sep 30, 2018
I need user manual for Targus laser pointer model AMP01US.
ManualsLib has the User Manual for the Targus AMP01US Wireless Multimedia Presenter with Trackball here: https://www.manualslib.com/products/Targus-Amp01us-7090628.html . You can download the manual from the Download button in the upper left corner of any page after the title/table of contents page. I hope this helps. Cindy Wells
9/2/2018 10:55:06 PM • Targus Computers... • Answered on Sep 02, 2018
Targus PAUH217U 4-Port USB Hub Logo
8 questions posted
Top Targus Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Targus Computers & Internet
Most Popular Question
cable targus 4 hub usb2 model pa055u
  • Computers & Internet
