Tip & How-To about Kitchen Appliances - Others
It is very resistant to scratches, is heat resistant up to 180°C and does not stain easily. ... However, unlike wood which can be oiled to remove stains or glass which can polish out scratches, your laminate worktop will need to be replaced if you do manage to damage it.
First, you can get the exact visual design that you wanted
and it will cost you considerably less. Second, laminate flooring can be
installed above and below the grade unlike hardwood flooring. Moreover, the
laminate flooring is installed without using any nails or glue which make it
much easier to it yourself. Furthermore, laminate flooring is extremely
durable, easy to maintain and can be replaced easily.
