SOURCE: set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the
clock/calendar key twice and the time will be diplayed, key in the info
as follows: 12:00pm would be keyed in as "12". "00", the
display will show 12.00 then press the clock/calendar key, the
correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
SOURCE: Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
SOURCE: looking for the manual for the Sharp EL-2630PIII
http://www.sharpusa.com/~/media/8C9B594394224D3DABF52671B634DDB1.ashx?cal_man_el2630P.pdf
SOURCE: change date sharp el-2630PIII
"GT": Grand Total
"•": Neutral
" ": To set up date, time, conversion
rate, and tax/discount rate, place the
switch at the "RATE SET" position.
Date:
• Enter in the order of month, day
and year, then press to
complete the entry.
• Use to separate month, day,
and year.
• When is pressed, the number
entered is evaluated and displayed
as "date" if the value is within the
following range; "Error" is
displayed otherwise, and the
previously set date is restored.
Month: 1 - 12; day: 1 - 31; Year:
2000 - 2099 (in 4 digits) or 00 - 99
(in 2 digits)
Time:
• Enter in the order of hour, minutes,
then press to complete the
entry.
(There is no entry available for the
seconds value. The clock starts at
zero second.)
• If the hour/minute digit is less than
10, it is not necessary to enter the
first digit "0".
• Use to separate hour and
minute values.
as "time" if the value is within the
previously set time is restored.
Hour: 0 - 23 (24-hour system for
the hour entry), Minute: 0 - 59
That wasn't very clear. The CE button clears the numbers from the screen but when I punch in other numbers, it calculates with the number I thought I had cleared.
Newer calculators have an ANS memory where the last result is saved. If you clear a number then press an operation key without entering a number first, the calculator uses the value saved in ANS memor
eg.
5+10=15 [press CE button] 2+ (17 APPEARS) The only way I find to truly clear is to turn unit off then back on. Is there a setting I can change? THank you in advance for your help!
i was having the same issue until i found that the * button on the far left at the bottom is what does the complete clear to start a new count.
