How do I set it so that numbers can be auto added in. For example if I'm adding a bunch of numbers and the same number comes up 2 or 3 times in a row - I'd like to just hit the add button and have those numbers automatically calculate in. Can this be done on the Sharp EL-1701C? Thanks.
Depends on the icon. For example in your browser you may have an icon for gmail in that case it would represent the number of new emails. If you have an ad blocker it shows the number of blocked ads. And so forth.....
To calculate: add up all the numbers, then divide by how many numbers there are.
Example: what is the average of 2, 7 and 9?
Add the numbers: 2 + 7 + 9 = 18
Divide by how many numbers (i.e. we added 3 numbers): 18 ÷ 3 = 6
So the average is 6
If your dryer is set to "auto dry" the display will show AD initially and then may show a number which is the estimated time for the clothes to dry in auto dry mode. The display may also show CD (Cool Down) and DN (Done) during the cycle.
The following are examples of expressions:
x 3 + 7
2 × y + 5
2 + 6 × (4 - 2)
z + 3 × (8 - z)
Example:
Roland weighs 70 kilograms, and Mark weighs k kilograms. Write an expression
for their combined weight. The combined weight in kilograms of these two people
is the sum of their weights, which is 70 + k.
Example:
A car travels down the freeway at 55 kilometers per hour. Write an expression for
the distance the car will have traveled after h hours. Distance equals rate
times time, so the distance traveled is equal to 55 × h..
Example:
There are 2000 liters of water in a swimming pool. Water is filling the pool at
the rate of 100 liters per minute. Write an expression for the amount of water,
in liters, in the swimming pool after m minutes. The amount of water added
to the pool after m minutes will be 100 liters per minute times m,
or 100 × m. Since we started with 2000 liters of water in the pool,
we add this to the amount of water added to the pool to get the expression 100 ×
m + 2000.
To evaluate an expression at some number means we replace a variable in an expression
with the number, and simplify the expression.
Example:
Evaluate the expression 4 × z + 12 when z = 15.
We replace each occurrence of z with the number 15, and simplify using the
usual rules: parentheses first, then exponents, multiplication and division, then
addition and subtraction.
4 × z + 12 becomes
4 × 15 + 12 =
60 + 12 =
72
Example:
Evaluate the expression (1 + z) × 2 + 12 ÷ 3 - z when
z = 4.
We replace each occurrence of z with the number 4, and simplify using the usual
rules: parentheses first, then exponents, multiplication and division, then addition
and subtraction.
(1 + z) × 2 + 12 ÷ 3 - z becomes
(1 + 4) × 2 + 12 ÷ 3 - 4 =
5 × 2 + 12 ÷ 3 - 4 =
10 + 4 - 4 =
10.
go to menu> settings> application settings > call> all calls> auto reject. In this u can either turn off auto reject by setting activation to 'off', or unselect any nos u added by mistake to the reject list
Go to 1)menu 2)select settings 3)application settings 4)select call 5)select all calls 6)select auto rejec 7)in the reject list untick the number you dont want to reject and then press save it will be saved and the number will not be rejected
Check your breakers. Mine was doing the same thing, all of the 120v parts of the machine were working. (blower/drum motor/ lights) However the element wasn't coming on. Went to the breaker and found that one side of the 2 pole breaker was tripped. Turned both off and back on. Heater started working again.
When you set the dryer on settings such as normal or permanent press, it engages the various sensors that help the dryer to make the most efficient use of energy. Moisture sensor, heat sensor etc. (THAT IS WHAT TURNS ON YOUR AD SETTING) Normally it selects a time based on factory settings that it believes your load should be dried by. Say 50 minutes at Normal (high heat, normal) Every so often during the cycle, the machine will check the humidity sensor and the other sensors and try to see if the dryer is still on schedule. Sometimes it will determine that more time is needed, occasionally less time. While it calculates, it displays the Ad meaning that the machine is on auto dry. TO TURN OFF AUTO DRY, set it to a time setting instead of a DESCRIPTION setting.
