Video downloaded to computer from YouTube using Freemake Video Downloader, burned to DVD - Memorex Video DVD 4x,4.7 GB, 120 min video. DVD will not play on the Minteck portable DVD player. Is the problem with the Mintek or with the download/burn process I have used? Help and suggestions are appreciated.
Do you use a DVD burning program or DVD copy program to convert ISO file to DVD? Normally, if you not, it is just data DVD and not a playable DVD disc for DVD player machine.
You can try to use some programs to copy ISO to DVD such as Leawo Blu-ray Copy or Windows Disc Image Burner. Microsoft has included a default feature of burning ISO files to DVD disc.
SOURCE: Charger for Mintek portable dvd player 1810
eBay has a few charges for your portable dvd player.
SOURCE: no disc error
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
SOURCE: how long does it take to charge the battery on a mintek MDP-1810 portable dvd player?
In most cases 8 to 12 hours to fully charge.
The problem I think is with the burner on your pc. Try re burning on another program like Nero and pay attention to the options. It will ask you if you wish to play disc in all types of players.
