Apple iPhone 5S Logo
A
Anonymous Posted on Mar 03, 2015
Iphone 5S has large print on screen & I can not move around
Phone screen has very large print. I can not get this print to go away
Moath Al Jabareen
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Mar 04, 2015
Moath Al Jabareen
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
2894
Points
34
By 3 fast clicks on home button, then you choose "zoom"
Daniel Mc Entee
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,449 Answers
  • Posted on Mar 03, 2015
Daniel Mc Entee
Master
Level 3:
Renaissance:
Answers
1449
Questions
0
Helped
275891
Points
3556
Click on it and hold it then try move it down.
IPhone 5S screen and digitizer are broken, can I still back it up to my computer?
yes you can, just connect it to the computer. Don't let it update to IOS 8.2, because it will ask you for the code on the iPhone screen.
Then iTunes will backup your phone.
At least I hope you already did backup it at least once.
I don't know what happens when you connect the phone to iTunes for the first time, because that was so long ago.
Success.
The itunes screen wont go away how do i fix that?
double press the home (round button at the bottom of the phone screen) twice and swipe up over iTunes (or music) to close that app. no reliance music and it should be back to normal
How to fix iPhone screen when it stops working.
Make sure you try restarting the actual phone by holding down both the lock screen button and the home button. if that doesnt work you'll have to completely restore the phone to remove the bug and use as brand new. DO NOT back up the phone to put everything back on because the bug will go straight back on aswell.
My iphone 5s wont slide open it rings i have restored it it just wont open.
Well, based on the wording of your question, I assume that when you attempt to slide your lockscreen away to unlock the device, that the lockscreen doesn't slide or respond to your finger movement. If touching the screen gives you no response at all, (which you can test by sliding to power off after holding the home button as an alternative) then your issue is a malfunctioning digitizer.
The digitizer is the touch sensitive glass component of the phone, and is attached to the LCD screen on the inside of the phone. These can be ordered on amazon.com as one piece, and you can either replace it yourself or find someone who could replace it for you. If you don't wish to go through all of that trouble, then you may want to consider either replacing the phone, or bringing it into an Apple retail store. If your phone is still under warranty, then the Apple store may just give you a new phone free of charge (which is what happened to me when my iPhone 5 malfunctioned.)
Hopefully this helps, good luck!
My iphone 5s from mycricket is telling me invalid imei when i check the status of my imei on imei.info
hi. back up your info & reset the phone . setting general about all the way down & choose the second one erase all setting & content .
if you need the imei you have them on the box or in the back of the phone .
2helpful
4answers
How to tell if an iPhone is a 5 or 5S?
The physical differences between the iPhone 5 and 5S are the camera flash and the home button. iPhone 5 has a single LED flash while the iPhone 5S has a dual LED flash. And the iPhone 5 home button doesn't have the circular ring around the button which is the finger print sensor unlike on the iPhone 5S.
Why is the display smaller than droid phones? This is one downside I have with Apple iPhone
The display is smaller than droid phones because the experts at Apple determined that the ability to reach all the way across the phone with your thumb was more important that a large screen. They wanted to make the phone usable in one hand. (It appears to have worked, too if you notice how many iPhone users have their phones out all the time)
Does the iPhone 5s come with black around the edge of the screen?
It looks like for now the only iphone 5s that has the black around the screen is the grey, the other 2 options both have white around the edges.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
