Cyberhome CH-DVD 300 DVD Player Logo
Mary Wojciga Posted on Jan 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen says INSERT DISC after I have put the DVD in. What's wrong?
Nanny
Level 3:
Genius:
  • Cyberhome Master 2,351 Answers
  • Posted on Jan 14, 2020
Nanny
Cyberhome Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988634
Points
7262
1. Incomplete disc information or scratched disc. This is the main reason for the issue. Before you try anything to examine or fix your DVD player, it's suggested that you make sure the disc you are trying to play is intact and well. If it's the problem of your disc, then trying to fix your DVD player does not help at all. In this case, you can copy the scratched DVD disc and then you may play it on your player machine.
2. The disc is incorrectly formatted. A common DVD disc or Blu-ray disc is formatted in various ways. You can find different DVD or Blu-ray disc types in the market, such as DVD-RW, DVD-R and 4K Blu-ray disc and so on if the disc is not formatted correctly in accordance with the player, then it will not be detected. You can use some software tools to correctly format your DVD disc.
3. The glitch of the DVD laser lens. Most of the DVD "No disc" problems are caused by the glitch of DVD laser lens. The cleaning DVD laser lens is not easy and requires patience and carefulness. You can start out by trying to blow away the dust if that doesn't work, you can try using a DVD cleaning disc.
2 Related Answers
haneefa
Digital Service Centre
  • 80 Answers
  • Posted on Mar 29, 2009
SOURCE: The screen says no disc even when I put a DVD in
Dear friend,
Pls clean ur dvd palyer lense or replace ur lense
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Mar 21, 2010
SOURCE: PCH-DVD 300 says every disc I insert is a "Bad Disc"
First thing to do is clean the lens with a good quailty DVD lens cleaner, it that doesn't work you have a fault, in either the lens or the electronics.
Disc says loading and goes no further
First try different DVD discs. All players of DVD or CD are likely to fail in this way over time. You can try to clean the lens inside the unit, but it may not fix it. Its wise to buy the cheapest replacement, because they never last much longer than a year.
When I insert a dvd the screen tells me I have the wrong region
  1. Make sure there is no disc inside
  2. Close the disc tray
  3. Press MENU, 1, 9
  4. Press ENTER
  5. Enter 0 for multi-region
  6. Press ENTER
  7. Press OPEN/CLOSE
2answers
Dvd says wrong disc
common problem is due to the dirty eye lense, try to insert lense cleaner,or clean manually with cotton buds,if not,maybe the lense is blurred already,it can be relaced
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
2answers
Wrong disc?
to clean the lens you'll need to buy a lens cleaner.its a cd which cleans.so its no problem to load it.now if even the lens cleaner is not loading ,i suggest you bring it to a tech nearest you.
2answers
Reads "wrong disc" when I insert any disc
Tru cleaning your lens,(pysically) give it a blow ,or similar
When I put certain dvd's it would say I should still insert a dvd.
that happens when u insert a disc of the wrong region,PAL disc in NTSC only player and vice versa or if the disc is damaged and cant be read..hope it helps!
Disc read error
Sounds like the laser has gone or the try is not fully loading the disc.
DISPLAYS WRONG DISC EVERYTIME I PUT A DISC
Tried inserting a cd with music or mp3s? If a cd will play and not a dvd it may be a country code problem.
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
