Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
I think you might just have shut it off.
Press '2nd' then M+.
P/NP = Print / NoPrint
the '2nd' button will allow you to choose the fonction on top of the M+.
the F is for the decimal. ( wich you can set as F-Floating, 3 decimal, 2decimal, 1 decimal, 0 decimal. A- the number will be in the decimal if you dont put a '.' )
the arrow is the way its rounding the numbers
