SOURCE: item count on el-1701c
Helloooo
There is a switch located above the keyboard labled IC for item count...slide the switch to the on position and as you add a number will appear on the paper tape on the other side of the total. On some units it will appear on the Display also.
I hope this solves you problem.
Squipps
SOURCE: Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
SOURCE: I have a Sharp EL-1701C Calculator
Hi cherycooney,
Press the '2nd' button, press the 'M+' button. 'NP' should appear on the display screen, and print function will be turned off.
Thanks for using Fixya.
SOURCE: How can I get a manual for the SHARP EL-1701C?
lOG INTO GOOGLE AND REQUEST A FREE DOWNLOAD IT SHOULD BE AVAILABLE
