Cameras Logo
Posted on Nov 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can a 18650, 3.7 V, 2200 mAh battery be replaced with a 18650, 3.7 V, 3400 mAh battery?
Not Me
Level 3:
  • Cameras Master 3,158 Answers
  • Posted on Nov 09, 2019
Not Me
Cameras Master
Level 3:
Answers
3158
Questions
0
Helped
163309
Points
31816
Make sure that both batteries are the protected type
https://commonsensehome.com/18650-battery/
Dalton Benjamin
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Nov 13, 2019
Dalton Benjamin
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
4339
Points
Yes but I wouldnt use the two different mAh together at the same time
1helpful
2answers
Can i use a rechargable battery which is rated 750 mAh(1.2v) if the one in the phone is 850 mAh (1.2 v)?
No it would not be advised to go for a lower mAh as your phone would not perform as eficiently and also too I would recommend to replace it with same as qriginal 1.2 v -Ni-MH battery . And you can get any battery from Amazon .Com at avery good price, that is my go to place if I want something specific.
Does the value of a battery capacity(mAh),larger than that specified for a laptop,mean any damage when used with it?
No it doesnt.. It just means that the battery can hold a larger charge.. I.E. the laptop will run longer then one with a lower mAh..
Philips SE 455 twin set cordless: The charge lasts less than an hour when using speaker phone, so I am looking for replacement batteries. Phones only 2-3 years old and absolutely fine in all other...
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
1helpful
Can i replace my 800 mah cell phone battery with 1000 or 1300 mah battery
You can replace current battery 800 mAH with higher mAH, but make sure the voltages are really same so that, you still can use your charger and the new battery will not damage your phone.
Regards,
Jan 16, 2011 • Cell Phones
Sony DSC-P93 battery replacement question
NiMH batteries. You can use the larger mAh AA. It has more capacity and should give you longer service before needing recharge. The battery manufacturers recommend that you do not mix the batteries. i.e. don't use mAh 2100 and mAh 2500 as one set, use all 2100 or all 2500 as one set.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
