The leak is under the washer at the left front - not a ton but enough. What to do?
SOURCE: Duet washer leaking
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
SOURCE: Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
SOURCE: front loading washer leaks
The rubber seal (or bellow) wears with age and will eventually deteriorate over time. Excessive use of detergent, and/or use of the wrong detergent (detergent that is not HE) can contribute to rubber breakdown too. Regular detergent is formulated for washers that use a wash tub with a capacity of 35 gallons. HE detergent is formulated for High Efficiency washers that only use 5 to 7 gallons of water. So, if you place regular detergent in an HE washer, you are (in affect) putting a higher concentration of soap in your washer. This higher concentration of soap can act as a corrosive to rubber and become permeated in your clothing as it does not rinse completely. This can lead to skin irritations as well. It is important that if you are not using HE detergent that you do so in the future to prevent premature breakdown of the rubber seals of the washer and pump. This will also void most manufacturer warranties if it determined you are using improper detergent. Now...I'm not trying to accuse you of abusing your appliance and not trying to lecture you. I'm merely putting this information out, because some people simply do not know. Overloading the washer is another contributor to excessive wear on the bellow as well as not keeping the bellow cleaned properly. Mold and mildew can contribute to the break down of rubber. The following link can give some advice on proper care of the door bellow:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
Since your bellow is already leaking, it must be replaced. Replacements can be ordered on line at either searspartsdirect.com, repairclinic.com, or pcappliancerepair.com. All these websites offer competitive pricing, so you can shop for the best deals. Just type in your COMPLETE model number to begin your search. The Sears website offers helpful exploded view diagrams to assist in part identification and location. NOTE: You may consider ordering the front and rear bellow clamps if yours are damaged. Refer to the Sears website for pictorial view.
If you need assistance in replacing the bellow, the following link will give you the steps necessary to complete this repair on your own:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
SOURCE: top load kenmore 110
it's your pump! thats the most common leak on kenmore top loaders.it located low ,front and .you can tip washer back towards wall and inspect.the pump is white and has two hoses to it.
SOURCE: My Whirlpool Duet dryer is leaking water.
Any dryer leak but not work with water, maybe you put the clothes very wet.
Testimonial: "So you think the problem may be with the washer not sufficiently drying out the clothes? Should I run the washer through another spin cycle?"
