Washing Machines Logo
Elena Rotunno Posted on Nov 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a whirlpool duet ht, the control locked light is on, the machine won’t go on. I tried unplugging it pressed the control on. Nothing Can you please help?
Ned Halaweh
Level 2:
  • Expert 240 Answers
  • Posted on Nov 14, 2019
Ned Halaweh
Expert
Level 2:
Answers
240
Questions
0
Helped
49798
Points
502
Is the child safety lock on??
Try hitting the safety lock button for 3 seconds to unlock it. Best of luck.
Ned
Tom Guadagni
Level 1:
Habit-Forming:
New Friend:
  • Contributor 33 Answers
  • Posted on Nov 13, 2019
Tom Guadagni
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
33
Questions
0
Helped
12897
Points
77
It should be flashing a code that you can look up. A common code is for the pump to be jammed with something. It can be freed up through an access point under the lower front cover.
5 Related Answers
kd3ke
  • 23 Answers
  • Posted on Jan 27, 2008
SOURCE: whirlpool duet ggw9250pl1
On Duet models, Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Locked feature.
Anonymous
  • Posted on Feb 03, 2008
SOURCE: whirlpool Duet
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Anonymous
  • 100 Answers
  • Posted on Mar 28, 2009
SOURCE: Duet HT GHW9300PW4 - The control lock is on
It should be the end of cycle signal volume botton
Chris Hendrick
  • 26 Answers
  • Posted on Jun 03, 2009
Hold down "end of cycle" button for 3 seconds.
chrisxx
Anonymous
  • 1430 Answers
  • Posted on Nov 26, 2010
SOURCE: Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
4answers
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
1helpful
I have a whirlpool duet HT. The control lock botton is on. So the washer will not start it does nothing. I unpluged it, hold in the unlock door botton nothing works. The door opens and close I just...
Hello Welcome to FixYa here is the answer your searching for..Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked. If this was helpful please rate me Thanks :)
The duet washer has been unplugged overnight. The control locked light is on and won't shut off. Pressing the end cycle button does nothing. What else can we try?
try holding the sop/cancel button for 15seconds, this should reset it but may not completely remedy the problem. after you reset it see if any other lights blink or if any other problems arise
Control lock llight is on kenmore duet washer
hold the end of cycle button for three seconds it should come unlocked then
21helpful
chrisxx
1helpful
1helpful
2answers
Control Lock is on, how do I reset the machine?
Press and hold down "end of cycle" button at right side of panel for 3 - 5 seconds. This is the child lock feature, do it again and the machine locks.
62helpful
21answers
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
2answers
Flashing Control lock light
Press 'options' & 'select' for 5 to 6 seconds, controls may unlock (depending on your model) If it is a key you see, it is the child lock.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
