How do you change the ink ribbon cartridge on the royal scriptor typewriter?
SOURCE: RIBBON CHANGE
Make sure the ribbon is facing the correct side. Usually, there is a small encave which is to be facing downwards. Snap it in place and you are good to go.
Zabrina
SOURCE: Brother SX-4000 Typewriter - problem w/ ribbon
Make sure ribbon you have if for the typewriter you have. take ribbon off machine and type characters, you should see the small ribbon (black) part that turns the ribbon move. If not you have a problem in the printer carrier itself...
SOURCE: Changed Ribbon
I bought the ribbon and it did not work so I took it back got another
one and it still will not type
Please help
SOURCE: Ribbon not advancing on Selectric II typewriter
on the left far side of the ribbon there is a white vertical post. the ribbon should be on the left side of that. also make sure you turn the ribbon the direction of the arrow (on the cassete) otherwise will need professional repair
SOURCE: Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
