Sharp EL-1701C Calculator Logo
Posted on Nov 18, 2009
How can I get a manual for the SHARP EL-1701C? Can I view the manual online?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 18, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1814
Points
7
LOG INTO GOOGLE AND REQUEST A FREE DOWNLOAD IT SHOULD BE AVAILABLE
Need a manual for a Sharp EL-1701C - NOT EL-1701V
It does not appear that a manual is available for this model.
However, you can contact Sharp directly at -
https://sharpcalculators.com/contact-us
When adding on My Sharp EL-1701C calculator it will stop adding and show a P. E
The P stands for power & usually means you need to change your battery
56helpful
I have a Sharp EL-1701C Calculator
Hi cherycooney,
Press the '2nd' button, press the 'M+' button. 'NP' should appear on the display screen, and print function will be turned off.
Thanks for using Fixya.
11helpful
I'm trying to load paper into a Sharp el-1701c that I inherited.
My wife solved it by finding a thin little slot on the back of it where you put the paper in. Worked
beautifully. Thanks any way.
1helpful
Item count on el-1701c
Helloooo
There is a switch located above the keyboard labled IC for item count...slide the switch to the on position and as you add a number will appear on the paper tape on the other side of the total. On some units it will appear on the Display also.
I hope this solves you problem.
Squipps
15helpful
Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
