There is a way with the original Mitsubishi remote to do a hard reset of the set; it will return the set to the condition it was when new in the box.
It is done with the original remote and a four digit number entered with the remote.
The set will turn off and come back on in the Air band on Channel three. Any labels on inputs will be gone.
If you want to try this confirm the actual model number and I will tell you the 4 numbers.
SD TECH and I am in California.
The previous owner may have locked the speakers out if the option is grayed out.
Here are the instructions for the hard reset that should restore them, they are for the model WS-65909 and if the model is different let me know before you attempt it.
With the original Mitsubishi remote and the set already on: menu, 0,1,7,0 enter (some versions do not require the menu first)
the "OPTION" MENU WILL COME UP ON SCREEN, select reset or something like that and highlight it with the up/down cursors on the remote and hit the enter button.
SD TECH
Here
the
enter button.
SD TECH
I have a wd-73909, what is the code for this set?
for the wd model before attempting a hard reset try the soft on, power set on and then with Mitsubishi remote try menu, 1,2,3 enter
If you don't have speaker jacks for external speakers on the jack panel then you can't use the speakers that way. You will have to use the audio out (rca jacks) and run them into a surround sound system or a regular stereo system. The grayed out means you only have internal speakers of which you can turn off once you connect the audio out to a amplifier, then your ready to go.
I need you to unplug the tv for 5 min and then plug it back in. go to the audio menu and double check all your settings. When the sound is grayed out usually means the data-serial lines are interrupted in which the cpu does not recognize that option. If it persists then you will have to a service co.
I'm actually trying to just use the internal speakers with no other speakers hooked up and it's not giving me the option to turn them on.
Sorry, my first question wasn't clear.
I received a Mistubishi Diamond tv that had previously been hooked up to external speakers. I just want to use the internal speakers, but when I go to setup, it doesn't give me the option to turn on the TV speakers (it's grayed out). How can I turn on the internal speakers?
Hi there, thanks so much for your help.
It's a HDTV 1080 Integrated Series. The manual I have is for the WS-55859, WS55909, WS-65869, WS-65909 and WS-73909. The screen is about 50 inches. Sorry, I can't find anywhere that it tell me the exact model. Thanks!
You are amazing! It worked! Thank you so much!
Fantastic! Perfect instructions!!!
