Televison & Video Logo
Tamela. Isble Posted on Nov 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 32or a 36flat screen Dynex tv and I can't get it to program any channels it was working 4days ago just fine and now nothing.
Joe V Bolin, Sr
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Nov 14, 2019
Joe V Bolin, Sr
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
756
Points
9
Obtain a manual here: https://www.dynexproducts.com/pdp/DX-32L220A12/1854819
Resetting the tv will help sometimes. Turn it off with the power button on the set, not remote. Then unplug power cord for 3 minutes & plug back it and turn on with power switch. You'll have to re-setup the tv.
Level 3:
Top Expert:
  • Dynex Master 76,851 Answers
Dynex Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008529
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
5 Related Answers
Anonymous
  • Posted on May 23, 2008
SOURCE: Programming Scientific Atlantic remote to work with New Dynex TV
dynex is bestbuy's product try emerson, mine is working with emerson codes
Anonymous
  • Posted on Jan 06, 2009
SOURCE: User Manual for (Dynex) DX-LCDTV19
Go to the Dynex web site. Type your model number in the search box and follow the link to the user manual.
Jaime Hernandez
  • 2351 Answers
  • Posted on Sep 28, 2009
SOURCE: Dynex DX-LCD32-09. tv was working fine, then out
This type of failure could be in the LCD controller board or the power supply might not be providing enough voltage to the main board and LCD controller.
Let me know if you require further assistance locating the boards or part numbers.
Anonymous
  • 157 Answers
  • Posted on Oct 07, 2009
SOURCE: TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Anonymous
  • Posted on Jan 03, 2010
SOURCE: 19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Dynex TV came on black and the buttons aren't working?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
3helpful
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
2helpful
Dynex 22 tv has sound no picture
Power supply caps or backlight inverter! Common issues with LCD flat screens for some reason.
Hi everyone, Im new to this thread, but I have very high IT experience. However, I have a problem that I just cant figure out. My Dynex tv randomly started acting up. All my colors and channels are...
check the connection to your tcon board and main av board. if the connections are good one of these boards is more than likely bad. Google their part numbers and see if that board has a known issue
thanks,
michael
Dynex flat screen- cogeco box- guide works then goes blank
Not the remote.It the Cogeco box.The box data's it out of dated,some time this happen.Unplug the Cogeco box about an hour,replug the box.Let it update it software.Goto the tv setup goto CH. rescan it again,all the tv channel should be back.
1helpful
TV screen went negative. Brand new TV
I would use the warranty for this problem. The part that need to be replaced can be somewhat expensive.
With the credit card statement, you can use that as a receipt.
2helpful
3answers
Trying to program the tv with the direct tv remote
Not out of luck, Dynex.com says to use codes from other model of televisions. The way I did it (I have a DirecTV remote as well) is just did a code search till I found which one turned it off. The only thing it won't do is change which input you use, but the menu, volume and channel controls all work fine.
9helpful
4answers
No picture - 65535 shows on screen
My 42" Dynex just did the same thing. 65535 NO SIGNAL.
The channel label for this said "ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ"
I went to menu... Channels .... Set for Cable TV... Scan Channels.
It rescanned. It took twice as long as normal to scan.
After the scan completed it worked fine except of one thing.
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ stuck on the screen.
I shut the TV off, then things returned to normal.
Hope this helps.
Notes:
This TV is only 6 weeks old.
Cable hook up.
It is -plugged into a brand new UPS power supply.
I used the sleep timer to shut off TV. The 65535 problem occured the next time the TV was powered up.
4helpful
4answers
Dynex (no database) since power outage
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
2helpful
Dynex 19" tv
Go into the setup screen on the TV and set the channel option to CABLE (it is probably set to AIR right now or something).
The website should also have a manual for how to program the remote.
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
