20 Most Recent Sharp EL-1701C Calculator Questions & Answers
HOW TO CHANGE INK RIBBON OR ROLLER
Once you open up the clear plastic cover, there is this tiny piece of black plastic at the right hand side, that's the ink roller unit (the ink roller is the bottom of the unit). You could try to remove it with your fingers. If you can't get it out, use a little screw driver and gently pop it out. You can find the replacement on eBay or other outlets, it is about $6 a piece (cheaper if you bulk-buy).
3/8/2021 8:39:35 PM • Sharp EL-1701C... • Answered on Mar 08, 2021
Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
5/21/2019 4:05:01 PM • Sharp EL-1701C... • Answered on May 21, 2019
manual
I have a Sharp EL-1701C Calculator
Hi cherycooney,
Press the '2nd' button, press the 'M+' button. 'NP' should appear on the display screen, and print function will be turned off.
Thanks for using Fixya.
2/14/2018 11:30:49 PM • Sharp EL-1701C... • Answered on Feb 14, 2018
0answers
2answers
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
3/31/2017 3:16:37 AM • Sharp EL-1701C... • Answered on Mar 31, 2017
Printing will not shut off
My calculator starts but it won't show anything in the window when I presses numbers
3/31/2017 3:12:17 AM • Sharp EL-1701C... • Answered on Mar 31, 2017
2answers
P keeps appearing
Have same problem with the randomly appearing"P" and no end frustration with it. Tried loosening, (...the screws very extreemly tight), tried with no success, then tightened again, but still no success. Thanks, though, for the suggestion!
3/31/2017 3:08:40 AM • Sharp EL-1701C... • Answered on Mar 31, 2017
How do you remove p.e off screen
I have found (somewewhere on the web, sorry cant remember where) that it is only a power error ! So if you see the P.e the calculator doesnt received enough power... All you gotta do is to change the batteries!! Or plug it with the appropriated power cord :) Enjoy!
3/31/2017 2:18:23 AM • Sharp EL-1701C... • Answered on Mar 31, 2017
What does the 5/4 and F mean on the display screen?
F is for floating decimal. If you do a calculation, it will present the results without rounding. For example, 1/2 would be displayed as 0.5, whereas 1/8 would be displayed as 0.125. The 5/4 rounds the results. For example, if the number of decimals is set to 0, 1/2 is 1. Similarly, if the number of decimals is set to 2, 1/8 is 1.3. Good luck, Paul http://support.casio.com/en/support/answer.php?rgn=5&cid=004001001004&qid=32&num=1
6/3/2016 3:01:12 PM • Sharp EL-1701C... • Answered on Jun 03, 2016
I need a user manual in PDF or Word format for this product and need to send this to someone as an attachment. via e-mail.
Not the exact model but might be useful: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000003742.pdf
2/19/2015 7:11:10 PM • Sharp EL-1701C... • Answered on Feb 19, 2015
How to change decimal point
If you want all entries and answers to have two numbers after the decimal, you should have a lever or slide that shows F,6,3,2,1,0. Some also show Add. Set the lever on the 2 or add. F means floating decimal. the others indicate how many numbers after the decimal.
11/1/2014 4:41:29 AM • Sharp EL-1701C... • Answered on Nov 01, 2014
Sharp EL-1701C Calculator Logo
114 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
old sharp el 1701c calculator some
  • Office Equipment & Supplies
