Cyberhome CH-LDV1010A Portable DVD Player Logo
Posted on Jul 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The dvd player will not read the disc - Cyberhome CH-LDV1010A Portable DVD Player
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Jul 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
3388
Points
34
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
  • bevclark1957
    bevclark1957 Jul 03, 2015
    But its only A week old!
Nanny
Level 3:
Genius:
  • Cyberhome Master 2,351 Answers
  • Posted on Jan 14, 2020
Nanny
Cyberhome Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989397
Points
7262
How to fix the "No disc" message and let the player play your disc successfully? You can try these: 1. Before you try anything to examine or fix your DVD player, it's suggested that you make sure the disc you are trying to play is intact and well. 2. If you are sure that there is something wrong with your player, you can press the "Eject" or "Open" button on the DVD player to disc tray to determine if it opens easily and does not appear jammed or hindered. If the disc tray appears to open slower than usual or fails to open, the disc may not sit flush in the tray or otherwise be seated properly. 3. Most of the DVD "No disc" problems are caused by the glitch of DVD laser lens.
Can't Read Disc
You could try updating the firmware.
DVD player won't read disc anymore
i had the same problem.
is the player done? or is there a fix?
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
DVD-Player not reading discs.
Well if it happens to every disc, then you know its the discs that are the problem. It should be the DVD player. Check if you plugged in the yellow, white, and red plugs accordingly. And also try blowing inside the DVD player, to blow away any dust that might be fogging the disc from beiing read.
Good Luck!!!! Rate Please!!!!!
2helpful
3answers
My dvd player is reading no disc
Either your lens of the dvd player is dirty or the dvd's you put in have no data on them
Won't pickup the dvd everytime
there are a few possibilties
1 make sure the disc is clean
2 your lens may need cleaning
3 some dvd players don't read burn copies of disc's some just read +R discs some just read -R disc
Hitachi dvd player not reading all dvds
Hello, I'm here try and help your problem, first older DVD players only read certain disc formats, If you have your owners manuel to your DVD player it will tell you what types of discs the DVD player will play. There are seneral types of burnable disc's DVD -, DVD +, DVD-R, DVD+R, DVD-RW, DVD+RW, please looking in the owners manual for the types of discs that the player will read, also in the same secton it will tell the types of formats that it will read DVD Video, DVD ROM, and there is a few others, Next is when you burn DVD's the type of burner you have makes a difference. You will need to find out what format your DVD burn, burns to disc, some of the newer DVD players
read alot of the formats. I would start by finding out what your DVD burns first, then I would suggest buying a DVD player that will read that format. If you have anyother questions please feel free to post them, Thank You and have a great day.
2answers
Some dvds do not run properly in my dvd player
check the region code of the dvd that u bought...if its not according to your country region code then the dvd would play only in laptops and pc dvd drives..u can contact the service station of philips and ask them to unlock ur dvd player so dat it becomes region free..i had the same issue with my dvd player
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
