I put a fuse in the port in the fuse block, got the numbers but can't find the diagnosis answers
SOURCE: location of fuses for 97 geo metro
It's either under the dash by your left knee or down on the drivers side kickpanel.
SOURCE: laging 1994 metro geo that is losing horse power
If your geo is losing power ,first thing to do is a comprision test .
if its testing any thing below 100 psi you may have to replace the piston rings.
SOURCE: 1994 Metro Geo rough idling and lagging up hills
dunno if it'll fix it- but check your pcv valve - 5$ for a new one - also check your egr valve- should be able to move depress it with your finger- if not, carb cleaner is safe to use to clean it up- remove it and clean it. this should help the idle
